12 years agoLPM_ROM, I am a newbie please help.
LIBRARY ieee;
USE ieee.std_logic_1164.all; LIBRARY lpm; USE lpm.lpm_components.all; LIBRARY altera_mf; USE altera_mf.all; ENTITY LPM_ROM_MEGAFUNCTION IS PORT( A_address :IN std_logic_vector (7 downto 0); Sclk :IN std_logic; Data :OUT STD_LOGIC_VECTOR (0 DOWNTO 0)); END LPM_ROM_MEGAFUNCTION; Architecture Behavioural of LPM_ROM_MEGAFUNCTION is component Variation1 PORT ( address : IN STD_LOGIC_VECTOR (7 DOWNTO 0); clken : IN STD_LOGIC := '1'; clock : IN STD_LOGIC := '1'; q : OUT STD_LOGIC_VECTOR (0 DOWNTO 0) ); end component; --SIGNAL Signal_1, Signal_2, Signal_3 :std_logic; BEGIN address => A_address, clock => Sclk, q => Data End Behavioural; =============>GIVES THE FOLLOWING ERROR MESSAGE<================== Info: ******************************************************************* Info: Running Quartus II Analysis & Synthesis Info: Version 9.1 Build 350 03/24/2010 Service Pack 2 SJ Web Edition Info: Processing started: Fri Nov 01 19:54:35 2013 Info: Command: quartus_map --read_settings_files=on --write_settings_files=off LPM_ROM_MEGAFUNCTION -c LPM_ROM_MEGAFUNCTION Info: Found 2 design units, including 1 entities, in source file variation1.vhd Info: Found design unit 1: variation1-SYN Info: Found entity 1: Variation1 Error (10500): VHDL syntax error at LPM_ROM_MEGAFUNCTION.vhd(29) near text "=>"; expecting "(", or "'", or "." Info: Found 0 design units, including 0 entities, in source file lpm_rom_megafunction.vhd Error: Quartus II Analysis & Synthesis was unsuccessful. 1 error, 0 warnings Error: Peak virtual memory: 239 megabytes Error: Processing ended: Fri Nov 01 19:54:36 2013 Error: Elapsed time: 00:00:01 Error: Total CPU time (on all processors): 00:00:01 Error: Quartus II Full Compilation was unsuccessful. 3 errors, 0 warnings4 Replies
The rom instantiation is wrong:
LIBRARY ieee; USE ieee.std_logic_1164.all; LIBRARY lpm; USE lpm.lpm_components.all; LIBRARY altera_mf; USE altera_mf.all; ENTITY LPM_ROM_MEGAFUNCTION IS PORT( A_address :IN std_logic_vector (7 downto 0); Sclk :IN std_logic; Data :OUT STD_LOGIC_VECTOR (0 DOWNTO 0)); END LPM_ROM_MEGAFUNCTION; Architecture Behavioural of LPM_ROM_MEGAFUNCTION is component Variation1 PORT ( address : IN STD_LOGIC_VECTOR (7 DOWNTO 0); clken : IN STD_LOGIC := '1'; clock : IN STD_LOGIC := '1'; q : OUT STD_LOGIC_VECTOR (0 DOWNTO 0) ); end component; --SIGNAL Signal_1, Signal_2, Signal_3 :std_logic; BEGIN rom_unit : variation1port map
address => a_address,
clken => '1',
clock => sclk,
q => data
); End Behavioural;
--Look at this....
--You need the PORT MAP after the begin. I am not sure this will work for you --but it is definitely closer. LIBRARY ieee; USE ieee.std_logic_1164.all; LIBRARY lpm; USE lpm.lpm_components.all; LIBRARY altera_mf; USE altera_mf.all; ENTITY LPM_ROM_MEGAFUNCTION IS PORT( A_address :IN std_logic_vector (7 downto 0); Sclk :IN std_logic; Data :OUT STD_LOGIC_VECTOR (0 DOWNTO 0)); END LPM_ROM_MEGAFUNCTION; Architecture Behavioural of LPM_ROM_MEGAFUNCTION is component Variation1 PORT ( address : IN STD_LOGIC_VECTOR (7 DOWNTO 0); clken : IN STD_LOGIC := '1'; clock : IN STD_LOGIC := '1'; q : OUT STD_LOGIC_VECTOR (0 DOWNTO 0) ); end component; --SIGNAL Signal_1, Signal_2, Signal_3 :std_logic; BEGIN --address => A_address, --clock => Sclk, --q => Data THE_COMPONENT_YOU_WANT: Variation1 PORT MAP ( address => A_address, clock => Sclk, q => Data ); End Behavioural; - Altera_Forum
Perfect.... I spent three hours today writing it left right and centre again and again. But no Joy.
(Level of Happiness right now is 1000000000000%) Thank You Thank You Thank You Thank You Thank You Thank You - Altera_Forum
It compiled in first go, I would love to become Altera Guru like you guys :D
Thank you Both :) yet again Jasper4 & Bertulus. I will be on this forum a lot now lol in Gurus company.
