LPM_MULT not working for Cyclone 10 GX device
- 1 year ago
I could strip down the design, but I have some new information. I was able to work around the issue by changing the implementation style to "Use logic elements", in lieu of "Use the default implementation" or "Use the dedicated multiplier circuitry". I believe the default implementation is to use the dedicated multiplier circuitry. I think there really is a bug in the Altera LPM_MULT IP when using multiplier blocks.
Changed to "Use loigc elements"Signal Tap showing ckt works as expected
So you able to tap correctly with just LPM_MULT IP?
Sheng
- K_Crocker1 year ago
If lpm.hint is "DEDICATED_MULTIPLIER_CIRCUITRY=NO,MAXIMIZE_SPEED=5" multiplier operates nominally.
If lpm.hint is "MAXIMIZE_SPEED=5" multiplier always outputs 0 for my FPGA (10CX150YF780E6G).
