K_Crocker
1 year agoLPM_MULT not working for Cyclone 10 GX device
I can't get a simple LPM_MULT instantiation to work. It simulates fine in Questa, synthesizes in Quartus Prime 24.2.0 Build 40 06/27/2024 SC Pro Edition without warnings, but 'result' is always 0 wit...
- 1 year ago
I could strip down the design, but I have some new information. I was able to work around the issue by changing the implementation style to "Use logic elements", in lieu of "Use the default implementation" or "Use the dedicated multiplier circuitry". I believe the default implementation is to use the dedicated multiplier circuitry. I think there really is a bug in the Altera LPM_MULT IP when using multiplier blocks.
Changed to "Use loigc elements"Signal Tap showing ckt works as expected
ShengN_altera
1 year agoHi,
Are you use LPM_MULT instantiation? If yes, can you try with the LPM_MULT from ip catalog? Probably some setting is not allowed.
Sheng
K_Crocker
1 year agoYes. I created an instantiation with the IP catalog:
General tabGeneral 2 tabPipelining tab
