13 years agoLPC controller
Do Altera FPGAs support LPC (Low Pin Count) controller as soft-IP core? I couldnt find it. I am having to design a system where a CPU interacts with the FPGA through the LPC bus apart from PCIe. Or would I have to code my own controller? Thanks, Satish6 Replies
Wishbone is described here. http://opencores.org/project,wishbone,wishbone
If you don't want to use it, you would remove it and replace it with something else (Avalon-MM, ...) - Altera_Forum
--- Quote Start --- The source code for the Lattice controller is licensed only for use on Lattice devices. You'll probably have better luck with the OpenCores one as a starting point. http://opencores.org/project,wb_lpc --- Quote End --- yes thank you, but it is Wishbone LPC , what is wishbone? I know only principal of LPC signaling and protocol,please help me more about that. - Altera_Forum
You'll probably have better luck with the OpenCores one as a starting point. http://opencores.org/project,wb_lpc - Altera_Forum
I want help about Lpc bus controller, I want to connect my FPGA throw lpc to Motherboard(lpc host ) ,I want to use only Firmware memory and Firmware memory write Cycles.I see Lattice document but I can't find any verilog code , please help me.
thank you. - Altera_Forum
Thanks very much for the confirmation.
I would look for it in open cores, else sit down to code one myself. Regards, Satish - Altera_Forum
--- Quote Start --- Do Altera FPGAs support LPC (Low Pin Count) controller as soft-IP core? I couldnt find it. I am having to design a system where a CPU interacts with the FPGA through the LPC bus apart from PCIe. Or would I have to code my own controller? --- Quote End --- I don't recall seeing one from Altera. Have you tried looking at opencores.org? I vaguely recall looking at the LPC interface and it didn't look too hard to code a controller for it. If opencores does not have anything you want to use, code up an interface, and a bus functional model, and if you have trouble, post the code here. Note that if you post code with a Modelsim testbench you're more likely to get a response :) Cheers, Dave
