8 years agolow speed on hps to fpga bridge
hi , i successfully implemented s system which is working on linux. my qsys system consist of a custom component running at 10khz ( output of a counter passing to hps (32 bit)) and hps (with on...
8 years agomaybe baudrate of putty terminal is the problem. anyway now i am trying to save the contents in a output.txt file inside the sd card where the linux is running. i checked the directory using ls command in putty. i can see it . is there any way to copy the text file to pc.(is it possible ?). when i tried to copy using scp commend from embedded command shell, its showing permission denied.
so is it possible to copy it, if yes what is the command ? regards
