13 years agoLow Pin Count FPGA/CPLD for FIFO+bits
Hi I'm an RF engineer with experience of programming PCs, PICs, EPLDs etc. I did once do an FPGA many many moons ago. I can't get the selection tool to make much sense, so here is my spec...
13 years ago --- Quote Start --- "3 lots"? 3 channels? How many bits is each 80Msps data stream, eg., (8-bits plus clock) x 3 channels = 24-bits input + 3 input clocks --- Quote End --- 4 wires: 80MHz clock, 3x 80Msps datastreams, datastream1 = 4MSBs of channelA, then 4MSBs of channelB. datastream2 = 4MediumSBs of channelA, then 4MediumSBs of channelB. datastream3 = 4LSBs of channelA, then 4LSBs of channelB, having clocked out 8bits on each datastream the whole thing repeats. There is no 'latch' all timing is dead reckoned off a starting pattern. (yuk) --- Quote Start --- What logic levels? 2.5V LVCMOS, LVDS, CML, etc? --- Quote End --- 1.8V CMOS. (I believe.. silicon is still in development but nealy done) --- Quote Start --- Mashed up in what way? If its just the ordering of bits that is weird, an FPGA does not care. If the data is XOR modulated or 8/10B encoded, then the FPGA can decode. --- Quote End --- not xored etc. I know the FPGA shouldn't care but it will need sorting out inside the FPGA as the kit that follows does care. --- Quote Start --- Why a FIFO? Do you want the data output in a single clock domain? If so, are the three input clocks phase-locked, but arbitrarily skewed? --- Quote End --- The problem is the tester clock that the data has to be aligned too is not good enough to drive the RF, so we are forced to have two asynchronous clocks, they are almost phase locked, so even with thousands of samples we shouldn't get even one clock cycle drift. Trouble is "shouldn't" isn't "doesn't" and we can't afford to assume we won't get a problem... not if it risks bakcing up 10s of thousands of product chips. --- Quote Start --- "Extracting" in what way? --- Quote End --- The tester needs to be 'bus master' in whatever interface we have between the CPLD/FPGA and the tester. I'm envisioning a 12bit wide databus plus a few control lines, running at 20Msps. --- Quote Start --- Cheers, Dave --- Quote End --- thanks Mike
