13 years agoLow Pin Count FPGA/CPLD for FIFO+bits
Hi I'm an RF engineer with experience of programming PCs, PICs, EPLDs etc. I did once do an FPGA many many moons ago. I can't get the selection tool to make much sense, so here is my spec...
13 years ago --- Quote Start --- 1. data input to device is at 80Msps.. 3 lots plus external Clock. --- Quote End --- "3 lots"? 3 channels? How many bits is each 80Msps data stream, eg., (8-bits plus clock) x 3 channels = 24-bits input + 3 input clocks What logic levels? 2.5V LVCMOS, LVDS, CML, etc? --- Quote Start --- 2. data is all mashed up, so needs untangling, then FIFOing... ideally 24bits wide by 10, more if possible. --- Quote End --- Mashed up in what way? If its just the ordering of bits that is weird, an FPGA does not care. If the data is XOR modulated or 8/10B encoded, then the FPGA can decode. Why a FIFO? Do you want the data output in a single clock domain? If so, are the three input clocks phase-locked, but arbitrarily skewed? --- Quote Start --- 3. data then needs extracting on a parallel interface, 12 databits wide, plus a few control bits. --- Quote End --- "Extracting" in what way? Cheers, Dave
