15 years agoLoss of lock in the PLL of ALTLVDS_Rx
Hi, I have two similar boards based on Cyclone III. My project works in both boards. This project performs exchange of data between boards with LVDS (physical link is made by SATA cable and conn...
15 years agoPLL settings in ALTLVDS_Rx:
SDC pin name: inst24|altlvds_rx_component|auto_generated|lvds_rx_pll PLL mode: Source Synchronous Compensate clock: clock0 Compensated input/output pins: lvds_data_rx, lvds_data_rx Switchover type: - Input frequency 0:20.0 MHz Input frequency 1:- Nominal PFD frequency:20.0 MHz Nominal VCO frequency:639.8 MHz VCO post scale: 2 VCO frequency control: Auto VCO phase shift step: 195 ps VCO multiply: - VCO divide: - Freq min lock: 9.8 MHz Freq max lock: 20.32 MHz M VCO Tap: 0 M Initial: 3 M value: 32 N value: 1 Charge pump current: setting 1 Loop filter resistance: setting 24 Loop filter capacitance: setting 0 Bandwidth: 450 kHz to 980 kHz Real time reconfigurable: Off Scan chain MIF file: - Preserve PLL counter order: Off PLL location: PLL_2 Inclk0 signal: lvds_clock_rx Inclk1 signal: - Inclk0 signal type: Dedicated Pin Inclk1 signal type: -
