11 years agoLookUp Tables
Hello, I want to implement sine and cosine signals in vhdl to check a part of my code but i don't know how to initialize these sin and cos signals? please tell me what is the way to do it?
i have read that it is possible through LUT but i don't know what LUT is ???12 Replies
Hi! I have the same project.I want to create sin-signal for tests, but it's an error when I put negative numbers into .mif file. Insted of negative numbers Questa show me zeros.
How Can I solve this problem? Main code:
Testbench:module single_rom ( addr, clk, q ); //input input addr ; input clk; output signed q; //ip-cores rom_ip rom_ip_component ( .address (addr), .clock (clk), .q (q)); endmodule
Contents of .mif file:`timescale 1 ps/ 1 ps module single_rom_tb(); // test vector input registers reg addr; reg clk; // wires wire signed q; // assign statements (if any) single_rom i1 ( // port map - connection between master ports and signals/registers .addr(addr), .clk(clk), .q(q) ); //clk initial begin clk = 0; forever# 10 clk = ~clk; end //beginning address initial addr = 7'h00; //loop always begin @(posedge clk) if (addr >= 7'h64) addr = 7'h0; else addr = addr + 7'h1; end endmodule
Picture, you can see zeros instead of negative numbers: http://s7.hostingkartinok.com/uploads/thumbs/2014/11/03327b0a1b3e6e4dc3e1dd541e47935d.png (http://hostingkartinok.com/show-image.php?id=03327b0a1b3e6e4dc3e1dd541e47935d)WIDTH=16; DEPTH=110; ADDRESS_RADIX=UNS; DATA_RADIX=DEC; CONTENT BEGIN 0 : 0; 1 : 5; 2 : 15; 3 : 80; 4 : 345; 5 : 656; 6 : -1; 7 : -2; 8 : -3; 9 : -4; 10 : -5; 11 : -6; 12 : 20886; 13 : 22430; 14 : 23885; 15 : 25247; 16 : 26508; 17 : 27665; 18 : 28713; 19 : 29648; 20 : 30465; etc - Altera_Forum
A lut is a ROM containing all of the Sin Values - so for a table of sin(x) - x is the address to the ROM.
