15 years agolookup table using vhdl:
Hai! How to convert binary bits (eg."00") to digital symbols(eg."1/sqrt(2) ) using lookup tables in vhdl coding? Can anyone help me out please
You'll need to write a conversion function.
The IEEE floating point package should have them. http://www.vhdl.org/fphdl/ If you meant fixed point, you can get the same things from the fixed point packages on the same page. - Altera_Forum
How to write vhdl coding for the conversion of real numbers to binary (including decimal points) and more over which is synthesizable?
For two bits IQ mapping, you only have 4 IQ points (QPSK) hence one +/- amplitude level per I or Q. you don't need to worry about sqrt(2) since all levels are same and you can choose any high enough +/- value that suits your resolution.
for multi-level case e.g (16 QAM), you have at least two levels and then you need to scale amplitude according to constellation diagram(ratio). But this is not what you are after. - Altera_Forum
Modify the file that has just been posted for sin/cos
http://www.alteraforum.com/forum/showthread.php?t=26594
