Looking for help on constraint syntax
- 5 years ago
If I'm reading your document correctly, you're transferring between a 40 MHz clock domain and a 20 MHz clock domain. As such, you need a multicycle timing exception in your .sdc file. Going from a faster to a slower domain usually requires a -start multicycle to select the correct launch edge for the setup and hold analysis:
set_multicycle_path –from SYSCLK –to CLK20MHZSYS_ext –setup –start 2
set_multicycle_path –from SYSCLK –to CLK20MHZSYS_ext –hold –start 1
DSACK1 is launching at falling edge, but want delay it to next falling edge. In this case half-period is 25ns, so 50ns.
So, I have external clock as 50ns, half-period 25ns
create_clock -name {SYSCLK} -period 50.000 -waveform { 0.000 25.00 } [get_ports {SYSCLK}]
From the above, creating a virtual clock
create_clock -name {CLK20MHZSYS_ext} -period 50.000
The signal of interest constraint as below and give setup slack timing violation. How to make this delayed?
set_output_delay -clock CLK20MHZSYS_ext -max 7.5 [get_ports {DSACK1_n}]
set_output_delay -clock CLK20MHZSYS_ext -min 0.5 [get_ports {DSACK1_n}]
Then tried add this but still give violation
set_output_delay -clock CLK20MHZSYS_ext -clock_fall 50.000 [get_ports {DSACK1_n}]
-clock_fall is a switch indicating, for output delay, that data is captured on the falling edge of the virtual clock. I'm not sure why you have "50.000" there. You would still need -max and -min with 7.5 and 0.5, respectively.
So I'm still not clear what you want. Are you saying you want this signal launched by a falling edge (SYSCLK) and latched by the next falling edge of CLK20MHZSYS_ext? If you clarify exactly what edges you want to use for launch and latch, maybe even a diagram, that would help.
