GD76
5 years agoLooking for help on constraint syntax
There is a setup slack violation (see attached). The timing violation at RAM_CONTROL:i13|q3 to DSACK1. We are off by 2.477ns. Looking to understand what syntax for CPLD can be constructed to constrai...
- 5 years ago
If I'm reading your document correctly, you're transferring between a 40 MHz clock domain and a 20 MHz clock domain. As such, you need a multicycle timing exception in your .sdc file. Going from a faster to a slower domain usually requires a -start multicycle to select the correct launch edge for the setup and hold analysis:
set_multicycle_path –from SYSCLK –to CLK20MHZSYS_ext –setup –start 2
set_multicycle_path –from SYSCLK –to CLK20MHZSYS_ext –hold –start 1
GD76
5 years agoThe CPLD gets 20MHz clock. The SYSCLK is 20MHz. Not sure where you got the 40MHz from.
