9 years agoLooking for bigger, fasterFPGA with on-chip flash/imamge/code..
Hi guys. New here. New to Altera.
I am looking for a new FPGA for a project i am working on - something with on chip flash/image/code, like possibly the Max 10 series. I developed a project on the Spartan3AN to take advantage of on-chip flash. The chip resources are 80%+, including on-chip flash (no external storage required). I'm hoping the Max 10 can do better. http://www.alteraforum.com/forum/images/smilies/wink.png The Max 10 looks like a good chip, and the Altera programming tools & documentation are inviting. I'm just comparing Spartan3 devices to Max10 devices, gates vs. Logic elements, vs. CLB vs. Cells. bits vs. bytes. :p1 Reply
This is from memory, so you may want to double check:
A MAX10 Logic Element (LE) contains a 4-input LUT and a register. A LAB contains 10 LE. A Spartan3 slice contains also a 4-input LUT and a register. A CLB contains 4 slices. You can find the numbers you need here https://www.xilinx.com/support/documentation/data_sheets/ds706.pdf (page 1) https://www.altera.com/en_us/pdfs/literature/hb/max-10/m10_overview.pdf (page 6) But from a cursory look, it seems that the biggest MAX10 is considerably bigger than the biggest Spartan-3N in all aspects.
