16 years agoLock a clock to a 8B10B data stream?
Hi there, I am trying to find a way to synchronize a chain of equipments but don't want to use a dedicated clock network. If I use the transrecivers in Arria II GX to implement GIGE protoc...
16 years ago --- Quote Start --- To ask a possibly ignorant question: What's the purpose of "looping back" the received signal clock? It must be expected to result in worse jitter performance, even with a high quality external PLL. --- Quote End --- I didn't mean to "loop back" the clock to the upstream. The network is a chain of equipments. The receiver receives 8B10B data stream from the upstream, (hopefully) sync itself up and pass the data stream down the line with the transimitter. The objective is to sync all the equipments with clock info embedded in the 8B10B data stream.
