14 years agoLoading SRAM,SDRAM or FLASH on DE1, using Linux, without Qsys, SOPC or NIOS
I have a design which needs data preloaded into one or more of NVRAM and/or SRAM and/or SDRAM on a DE1. I am using Quartus II Web Edition 11.1 sp1. I am not using Qsys, SOPC or NIOS, as the d...
14 years agoGuys,
I have some doubts. I'm building a system based on another one that I have (DE2_NET - it is in DE2 CD ROM), so I'm trying to understand what the function of each memory element. We find these in the project (one of each): Avalon MM Tristate Bridge Flash Memory EPCS Serial Flash Controller SDRAM The Resect_vector is pointing to Flash Memory and the exception_vector to SDRAM. My doubts: I think that the the .elf is being downloaded to the flash memory, I'm correct? 1. What's the function of each one? 2. Why I need to use EPCS? 3. I only can use flash memory whe I'm using a Avalon MM Tristate Bridge? Ps.: I'm reding some documentations but the differences are still not clear. Thanks
