9 years ago
Loading rbf file on boot from within Linux...
For both support & feature enhancement reasons, for us it is desirable to be able to load a new rbf configuration into the FPGA when booting Linux. A reboot to implement the change is fine.
The target hardware is unavailable hence removing the SD card & replacing the rbf is not an option.
The good news is that with the Yocto releases with the 3.12 kernel, the rbf file is loaded in exactly the way I'd like: on boot - the target rbf file is in /home/root called DE1_SoC_Computer.rbf and it is loaded by /etc/init.d/programfpga which contains the following:
#!/bin/sh
echo 0 > /sys/class/fpga-bridge/hps2fpga/enable
echo 0 > /sys/class/fpga-bridge/fpga2hps/enable
echo 0 > /sys/class/fpga-bridge/lwhps2fpga/enable
dd if=/home/root/DE1_SoC_Computer.rbf of=/dev/fpga0 bs=1M
echo 1 > /sys/class/fpga-bridge/hps2fpga/enable
echo 1 > /sys/class/fpga-bridge/fpga2hps/enable
echo 1 > /sys/class/fpga-bridge/lwhps2fpga/enable
This is well documented in the Altera guide 'using linux on the de1-soc'.
Great.
Except we are using one of the Ubuntu releases with the later kernel and no GUI.
The files listed above don't exist, neither do the contents of /home/root including the corresponding .rbf file or the script /etc/init.d/programfpga. Under Yocto, the /sys/class/fpga* files are:
root@de1soclinux:~# ls /sys/class/fpga*
/sys/class/fpga:
fpga0
/sys/class/fpga-bridge:
fpga2hps  hps2fpga  lwhps2fpga
root@de1soclinux:~# ls -R /sys/class/fpga*
/sys/class/fpga:
fpga0
I can't see/can't find any reference on how to do this under Ubuntu - and what the corresponding MSEL switches should be (mine are currently set to '00000').
Under Ubuntu, the /sys/class files are:
root@DE1_SoC:~# ls -R /sys/class/fpga*
/sys/class/fpga_bridge:
br0  br1  br2  br3
/sys/class/fpga_manager:
fpga0
/sys/class/fpga_region:
region0
For reasonable operational requirements this is a Most Useful Feature. I'd be very grateful if someone who knows how to do this under Linux Ubuntu Desktop with the 4.5 kernel will give me an good walk through please.
Thank you very much in advance.
