raghad's avatar
raghad
4 days ago
LLM Implementation on Agilex 5 E-Series 065B Modular Dev Kit
I am currently working on deploying Large Language Model (LLM) inference using FPGA AI Suite on the Agilex 5 E-Series 065B Modular Development Kit.
I have two clear and specific questions:
  1. Is the Agilex 5 E-Series 065B officially supported for LLM / Transformer inference with FPGA AI Suite?
  2. Is the following workflow officially supported for LLM inference on this board?
  • Step 1: Export a pre-trained LLM from Hugging Face to OpenVINO IR format using optimum-intel
  • Step 2: Generate the target FPGA architecture file using architecture_optimizer for Agilex 5.
  • Step 3: Compile the OpenVINO IR model for the FPGA using:
    • dla_compiler → for Sequential flow, or
    • Spatial Compiler → for Spatial flow.
  • Step 4: Integrate the generated FPGA AI Suite IP into a Quartus Prime project, generate the bitstream, and program it onto the Agilex 5 E-Series 065B board.
  • Step 5: Run inference using the FPGA AI Suite runtime (host application).
I understand this may not be a push-button process and could require significant modifications to the generated RTL — but is this workflow still considered a viable starting point for implementing LLM / Transformer inference on the Agilex 5 E-Series 065B?
Thank you.
1 Reply
