Linux not Booting on custom Intel Cyclone V board
I was trying to build Linux file system from scratch for my custom Intel Cyclone V (5CSXFC6C6) board so I followed this (Embedded Linux Beginners Guide | Documentation | RocketBoards.org) guide. But it did not work out and I got a "Reset the board" error. I am using Ubuntu 18.04 and Quartus Prime Standard 18.1 edition.
Then, I tried the same procedure on Arrow SoCkit Evaluation Board 5CSXFC6D6F31C6N. The guide was accurate till step 8 (I wrote the preloader and u-boot.img on sd card and it gave the same output and errors of zImage as suggested in the guide) but since “rel_socfpga-4.1_15.09.01_pr” release is no more available for linux-socfpga from Altera, I had to opt for a newer version of linux-socfpga.
Now, newer versions of linux-socfpga do not support compilation using old “gcc-linaro-arm-linux-gnueabihf-4.9-2014.09_linux” as suggested in the beginners guide, so I had to opt for a newer “gcc-linaro-6.5.0-2018.12-x86_64_arm-linux-gnueabihf”. I further used “socfpga-5.15.50-lts” as the new and stable version of linux-socfpga for cyclone-v and buildroot to build the image but it also didn’t work out and u-boot output threw errors for commands like "fatload" command not used properly and "echo $fpgadata" was empty).
I tried another way (Building Bootloader for Cyclone V and Arria 10 | Documentation | RocketBoards.org 1) with Quartus 19.1 but it failed at bitbake step. It gave 2 errors after downloading 5+ GBs of data. I am stuck with this for more than 2 months.
Can anyone suggest a better way to build things for my custom board from scratch? All the guides available are specific to some software or hardware and none of them have resulted working linux kernel for me.
Note- Arrow SoCkit works fine when I load prebuilt image, which means all the hardware, sd card and switches are set correctly.
