19 years agoLinking of two FPGA
Hi all, I'm a student of Engineering of Telecommunications.In my thesys I must realize a digital circuit on FPGA,but I can't make it all on the same FPGA board,because of occupation of resources.S...
17 years agoHello there,
I have a similar problem pertaining two FPGAs together. Currently, my design has exceeded my FPGA's LE count and therefore, i am planning to connect two altera UP2 boards using JTAG. The UP board has a CPLD (EPM7128) and FPGA (Flex 10k). from my understanding, if Quartus detected the assembly is larger than the device, it will generate more than one programming file..such as pof_1. However, the web edition software could notgenerate more than one program file. Instead, i have this error: *** Error: Project requires 6182 logic cells, but the selected device can contain only 3744 logic cells Error: Can't find fit Error: Quartus II Fitter was unsuccessful. 2 errors, 1 warning Info: Allocated 180 megabytes of memory during processing *** Could it be my web edition quartus's limitation?
