11 years agolightweight bridge address for DE1-SoC board
Hi there! I try to do some exercises with Terasic's DE1-Soc Cyclone V board. As a first exercise I'm trying to send data from the HPS to the FPGA over the lw bridge, using the FPGA as an Avalon...
11 years agoIt's part of the HPS specs. I typically refer to this when I'm trying to figure out the memory map: http://www.altera.com/literature/hb/cyclone-v/hps.html (that bridge is "lwfpgaslaves"). When you connect the lightweight H2F bridge to soft logic in the FPGA, the physical address of the soft IP is 0xFF20_0000 + base address of soft IP.
