16 years agolicense setup cable question
Hi all, I had a question regarding with the license setup. As long as I have a Cat5 cable plugged into my ethernet port, Quartus is happy and every thing works well. However, when there is no...
16 years agoHi,
I'm not quite sure if I remember correctly, but I think this has to do with the XP function to save energy by shutting down the ethernet if not connected. This would imply the problem can be solved by deactivating the energy safe option on the ethernet, must be somewhere in the LAN device setup... I'm running Win7, otherwise I would check for the option... Sincerely, Carlhermann
