18 years agoLFSR as counter in VHDL
I am running a bit low on gates in a VHDL design, and I am replacing a counter implemented by addition with a counter implemented as an LFSR. The main crystal is 3.6864 MHz and the counter needs to h...
18 years agoWhy is an LFSR going to save you gates? A counter should use the carry-chain, and probably be the optimal size, i.e if you need 2^20 count, then it should only be 20 logic cells. You really can't store that much information with fewer bits, unless I'm missing something. Is there anything else that has a counter running, because resource sharing might be your best bet.
