12 years agoLED toggle
I'm trying what I thought would be a very simple programme to turn alternate LEDs ON and OFF every half second, but it isn't working as it should. It starts off OK, with the LEDs toggling about every...
12 years ago --- Quote Start --- I'm trying what I thought would be a very simple programme to turn alternate LEDs ON and OFF every half second, but it isn't working as it should. It starts off OK, with the LEDs toggling about every half a second, but the period soon increases, so that after 5 or 6 iterations, the LEDs are turning on/off about every second, then every 2 seconds, etc. After 15-20 seconds, one LED stays ON all the time, the other OFF. Following is the code I'm using :- ENTITY LEDToggle IS PORT ( clk :in STD_LOGIC; led0 :out STD_LOGIC; led1 :out STD_LOGIC ); END LEDToggle; ARCHITECTURE behaviour OF LEDToggle IS SIGNAL COUNT : INTEGER RANGE 0 TO 50000000; BEGIN PROCESS (clk) BEGIN IF clk'event and clk='1' THEN - COUNT<=COUNT+1; IF COUNT < 24999999 then LED0<='1'; LED1<='0'; ELSIF COUNT>24999998 AND COUNT<49999999 THEN LED0<='0'; LED1<='1'; ELSE COUNT<=0; END IF; END IF; END PROCESS; END behaviour; I'm using an EPM240T100C5 development board with a 50MHz oscillator. The LED's are on pins 2 and 8 and I'm using the clock on pin 14. Regards --- Quote End --- I don't see anything wrong with your code. I assume it must be something wrong with your clock
