16 years agoLED diode as indicator that FPGA works
I want to put some led diode as indicator that my FPGA works fine ( I use ARRIA II GX ). Is there a pin I can use as indication that my component works and in user mode ? PS -- I use JTAG configuration . Thanks...2 Replies
I know ,
But I do I put there LED so that it will "light" when the FPGA works when it is already connected to resistor and VCCIO , and those pins are driven high when the device ( === > no current passing) is on ? Thanks for your quick reply ... - Altera_Forum
Look up the CONF_DONE or INIT_DONE pins in the handbook.
IIRC, these are dual purpose pins, which can otherwise be used as regular I/Os.
