16 years agoLED diode as indicator that FPGA works
Hi, I want to put some led diode as indicator that my FPGA works fine ( I use ARRIA II GX ). Is there a pin I can use as indication that my component works and in user mode ? PS -- I use...
16 years agoI know ,
But I do I put there LED so that it will "light" when the FPGA works when it is already connected to resistor and VCCIO , and those pins are driven high when the device ( === > no current passing) is on ? Thanks for your quick reply ...
