11 years agoLE and memory blocks in a cyclone
Hello, I'm quite new in the world of the FPGA, indeed, I'm an engineer student in end-of-studies internship which is about using a FPGA. Well, I'm telling you that because I guess that you wi...
11 years agoLEs can be used as memory, but they are far less dense than ram. So you can quickly lose all your LEs to larger rams that have timing issues. LE rams are meant for small high speed applications.
