11 years agoLE and memory blocks in a cyclone
Hello, I'm quite new in the world of the FPGA, indeed, I'm an engineer student in end-of-studies internship which is about using a FPGA. Well, I'm telling you that because I guess that you wi...
11 years agoThere is also the option of memory that isn't part of the FPGA chip itself.
Some FPGA dev boards also have simple to use parallel static RAM. These are easy to use, see the data sheet. If no you might have DDR memory. Much harder to use, but also much larger. If you need that, search for example projects for that particular board.
