12 years agoLarge delay between DMA transactions
Hello , Does anybody know why there is a large delay between consecutive DMA transactions ( about 50 us ) ? I use Quartus 14.0 and Eclipse ARM-DS5 v.14.0 . Platform : SoCrates EBV board ...
11 years agoDear All,
We are utilizing HPS-side DMAC controller and very similar results measured as in case of the -jaro's comment (as saying "built-in DMA"). My question is why the buffer size is limited in 2 MB when alt_dma_zero_to_memory / alt_dma_memory_to_memory / alt_dma_reg_to_memory API functions are used? Symptom: if the buffer size is increased above 2 MB then an alt_dma_event_int_status_get_raw() never returns with ALT_E_SUCCESS. Neither Cyclone V SoC device handbook, nor ARM's CoreLink DMA 330 Controller technical ref. guide (http://infocenter.arm.com/help/topic/com.arm.doc.ddi0424d/ddi0424d_dma330_r1p2_trm.pdf) mention about this limitation. However this latter guide is useful if you want to modify the microcode program of DMAC controller. Thanks Zsolt
