12 years agoLarge delay between DMA transactions
Hello , Does anybody know why there is a large delay between consecutive DMA transactions ( about 50 us ) ? I use Quartus 14.0 and Eclipse ARM-DS5 v.14.0 . Platform : SoCrates EBV board ...
12 years ago --- Quote Start --- Hello , Thank you for reply. Probably you are right about possible reasons . I have added "alt_cache_system_enable(); //cache enable " function to the init procedure , but without success ( no influence at the large delay). The question is still open : how we can improve the built-in DMA ? At this moment I'm testing different properties of the SoC System , and my test programs are very simple , i.e code to test buit-in DMA is like below (main section) : int main(int argc, char** argv) { system_init(); //init: gpio , bridge , dma , timer , cache enable soc_int_setup(); //setup interrupt global_timer_init(); //start timer (i.e. 10 ms interval) uart0_init(); //start uart generate_test_data(); //generate Write_Buffer[] while (1) { if (GLOBAL_TIMER_SEMAPHORE==true) //triggered every 10 ms interval { GLOBAL_TIMER_SEMAPHORE=false; for (int i=0 ; i<128 ; i++) // try to call i.e 128 DMA transactions (every transaction has got the length 128 32-bits word) { LED_GPIO_State^= 0x10000000; alt_gpio_port_data_write(ALT_GPIO_PORTA, 0x10000000, LED_GPIO_State); // LED // // here is a large delay between LED and the time when DMA data are visible (about 50 us) // //call DMA , DMA transfer time is about. 3.3 us (approx. 307 MBytes/s) dma_test_memory_to_register( &Write_Buffer[0], (uint32_t *)(ALT_LWFPGA_BASE + ALT_LWFPGA_LED_OFFSET) , 128); // // small delay (approx. 4.1 us) to the time when "ALT_DMA_CHANNEL_STATE_STOPPED " is returned // } } //timer } //while return 0; } //main My questions : 1) Is it possible to change something in the code or DMA init to remove delays ? 2) Now I'm trying to implement mSGDMA on the FPGA and compare the built-in DMA and the mSGDMA. I have a lot of troubles with connecting mSGDMA to the HPS system ( not to the Nios !!! ) . Does anybody know how to do it ( especially how to write driver code for bare-metal aplication ) ? Regards -jaro --- Quote End --- I've successfully implemented the mSGDMA controler. It's quite simple if you know how to do it http://www.alteraforum.com/forum//images/icons/icon7.png If you need DMA to transfer data between FPGA --> HPS SDRAM or HPS SDRAM --> FPGA the mSGDMA module is much better than built-in DMA controler. System description: 1) mSGDMA module connected to F2S ( FPGA --> SDRAM bridge) , not to the F2H AXI. 2) mSGDMA setup: Memory -> Stream or Stream -> Memory Data width = 64 bits Data FIFO Depth =64 Desc FIFO Depth =64 Transfer Length = 1kB or 16 kB Burst enable , Max. Burst Count = 16 Measurements result: mSGDMA Transfer Length = 1kByte : 1024 packets * 1kB , Memory -> Stream , Throughput = approx. 290 MBytes/s (good !!!) 1024 packets * 1kB , Stream -> Memory , Throughput = approx. 290 MBytes/s (good !!!) mSGDMA Transfer Length = 16kByte : 64 packets * 16kB , Memory -> Stream , Throughput = approx. 378 MBytes/s (good !!!) 64 packets * 16kB , Stream -> Memory , Throughput = approx. 378 MBytes/s (good !!!) For built-in DMA I've got following results : 1 packet of 1 MBytes , Memory -> Memory , Throughput = approx. 423 MBytes/s ( very good !!!) 1 packet of 1 MBytes , Memory -> Register , Throughput = approx. 38.4 MBytes/s ( poor !!!) 1024 packets of 1kByte , Memory -> Memory , Throughput = approx. 16.1 MBytes/s ( very poor !!!) 1024 packets of 1kByte , Memory -> Register , Throughput = approx. 11.7 MBytes/s ( very poor !!!) The last results due to large delay between consecutive DMA transactions !!!! Important notices about mSGDMA and F2S implementation ( poorly documented) : 1) you must to service the signals :msgdma_valid and msgdma_ready on the FPGA side (i.e. connect these signals together !!!!) 2) you must to define ALT_BRIDGE_PROVISION_F2S_SUPPORT =1 in your Makefile (read in HWLib help) 3) you must to link assembly file like this : alt_bridge_f2s_gnu.s in your Makefile (read in HWLib help) 4) you must to initialize F2S bridge in your program !!!! i.e. alt_bridge_init (ALT_BRIDGE_F2S, NULL , NULL) Regards -jaro
