12 years agoLarge delay between DMA transactions
Hello , Does anybody know why there is a large delay between consecutive DMA transactions ( about 50 us ) ? I use Quartus 14.0 and Eclipse ARM-DS5 v.14.0 . Platform : SoCrates EBV board ...
12 years ago --- Quote Start --- The reason is likely because a lot of error checking and validation goes into building each of the DMA programs. Things such as the following: - validating that program buffer have enough space to contain the entire requested program - register and memory addresses are aligned - all loops well-formed - program is well formed - program is synced to RAM - (list goes on). Things you can do to improve performance are as follows: - Setup the MMU page table and enable all caching (for 14.0, if you are using a flat VM model, it will work correctly. What I call flat is when all virtual addresses matches with the physical addresses). - You can try hand editing out the error checking but I don't know how much gains it will get you. --- Quote End --- Hello , Thank you for reply. Probably you are right about possible reasons . I have added "alt_cache_system_enable(); //cache enable " function to the init procedure , but without success ( no influence at the large delay). The question is still open : how we can improve the built-in DMA ? At this moment I'm testing different properties of the SoC System , and my test programs are very simple , i.e code to test buit-in DMA is like below (main section) : int main(int argc, char** argv) { system_init(); //init: gpio , bridge , dma , timer , cache enable soc_int_setup(); //setup interrupt global_timer_init(); //start timer (i.e. 10 ms interval) uart0_init(); //start uart generate_test_data(); //generate Write_Buffer[] while (1) { if (GLOBAL_TIMER_SEMAPHORE==true) //triggered every 10 ms interval { GLOBAL_TIMER_SEMAPHORE=false; for (int i=0 ; i<128 ; i++) // try to call i.e 128 DMA transactions (every transaction has got the length 128 32-bits word) { LED_GPIO_State^= 0x10000000; alt_gpio_port_data_write(ALT_GPIO_PORTA, 0x10000000, LED_GPIO_State); // LED // // here is a large delay between LED and the time when DMA data are visible (about 50 us) // //call DMA , DMA transfer time is about. 3.3 us (approx. 307 MBytes/s) dma_test_memory_to_register( &Write_Buffer[0], (uint32_t *)(ALT_LWFPGA_BASE + ALT_LWFPGA_LED_OFFSET) , 128); // // small delay (approx. 4.1 us) to the time when "ALT_DMA_CHANNEL_STATE_STOPPED " is returned // } } //timer } //while return 0; } //main My questions : 1) Is it possible to change something in the code or DMA init to remove delays ? 2) Now I'm trying to implement mSGDMA on the FPGA and compare the built-in DMA and the mSGDMA. I have a lot of troubles with connecting mSGDMA to the HPS system ( not to the Nios !!! ) . Does anybody know how to do it ( especially how to write driver code for bare-metal aplication ) ? Regards -jaro
