12 years agoLarge delay between DMA transactions
Hello , Does anybody know why there is a large delay between consecutive DMA transactions ( about 50 us ) ? I use Quartus 14.0 and Eclipse ARM-DS5 v.14.0 . Platform : SoCrates EBV board ...
12 years agoThe reason is likely because a lot of error checking and validation goes into building each of the DMA programs. Things such as the following:
- validating that program buffer have enough space to contain the entire requested program - register and memory addresses are aligned - all loops well-formed - program is well formed - program is synced to RAM - (list goes on). Things you can do to improve performance are as follows: - Setup the MMU page table and enable all caching (for 14.0, if you are using a flat VM model, it will work correctly. What I call flat is when all virtual addresses matches with the physical addresses). - You can try hand editing out the error checking but I don't know how much gains it will get you.
