11 years agoLabVIEW interface using USB RAW to Cyclone V/ SoC-DE1 DPM
Developers,
I am trying to connect a LabVIEW V.I. through an USB connection to the SoC-DE1 development platform module. It is unclear to me if I should used the UART to USB connector or the USB1 or USB2 connector. I intended to use the USB RAW bulk interface from N.I. LabVIEW to communicate with the SoC-DE1 board. I do not know if the SoC-DE1 board has a default USB configuration (example would be control of test equipment) that I could implement easily into the LabVIEW design . If anyone could give me a path I should use, it would greatly be appreciated. Cordially, JB1 Reply
Labview products use Xilinx FPGAs. It shouldn't matter which FPGA or Dev kit you use, but this seems like a question for NI. Try their forum instead. http://forums.ni.com/t5/labview/bd-p/170
