14 years agoKarnaugh map importance!
Actually i'm introducing myself on the design of Aplication Specified and Logic Functions with an FPGA of Altera Cyclone III and my cuestion is about the iportance of the Karnaugh map, when i think i...
14 years agoI do not think knowing K-maps and other hand optimizations is useless when synthesis engines can do this for you. Blindly letting your tools do all your work for you can sometimes make you a lazy designer so having an understanding of hand optimizations is still a good thing if you ask me.
K-maps when you draw them out also give you a good idea how FPGAs implement combinational logic since FPGAs implement combinational logic this using lookup tables. Often the optimizations that you perform by hand using K-maps isn't needed in FPGAs since the FPGA lookup tables implement every combination of an output signal of the function.
