11 years agoJTAG-UART Help Needed
I am trying to establish a link between a PC and NiosII board to print characters on the LCD. I am trying to have a console of something similar on the PC where i can type or enter characters and will be sent to the DE2 board running NiosII and print them on its LCD. I have found an example that does something similar but there is no input to the board in real time from PC. __________________________________________________________# include <stdio.h># define JTAG_UART_DATA ((volatile int*) 0x10001000)# define JTAG_UART_CONTROL ((volatile int*) (0x10001000+4)) int main() { unsigned char hwld[] = {'h','e','l','o','\0'}; unsigned char *pOutput; pOutput = hwld; while(*pOutput) //strings in C are zero terminated { //if room in output buffer if((*JTAG_UART_CONTROL)&0xffff0000 ) { //then write the next character *JTAG_UART_DATA = (*pOutput++); } }} __________________________________________________________ As you can see, "HELLO" is hard-coded. I can see the text being sent to the Altera Monitor Terminal, My question is how can i type this in real time and have the board scan the JTAG-UART over and over again? What program shall i use? Thanks.2 Replies
that's right... do monitor the incoming receiving byte via GETinputString, and then process the string.
One way is to use the GetInputString command. Check out this design example on ALtera's design store: https://cloud.altera.com/devstore/platform/15.0.0/nios-ii-qsys-hello-world-lab/
look under the software directory for the hello_world_hardware_interrupt.c and you can use that as a guide.
