NikoR
7 years agoJTAG .svf instructions descriptions
I want to program an 5M240ZT144 with an *.SVF file from in an embedded system. The .svf generated from Quartus does a SiliconID Check and fails. I see in the file that it is done with other command...
JohnT_Altera
7 years agoHi,
Could you use the Quartus programmer to generate the svf file? This is to check if there is any issue by using manual generated file. You may follow the guide in https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd07222008_677.html
NikoR
7 years agoSorry, that line is "greyed out"... Why?
