NikoR
7 years agoJTAG .svf instructions descriptions
I want to program an 5M240ZT144 with an *.SVF file from in an embedded system. The .svf generated from Quartus does a SiliconID Check and fails. I see in the file that it is done with other command...
JohnT_Altera
7 years agoHi,
May I know how do you generate the svf file?
- NikoR7 years ago
Hi.
In Menu Assignments => Device => Device and Pin Options:
Under category Programming Files; check box "Serial Vector Format File(.svf)"
The compilation now generates an .svf file. File attached.
-Nikolay
