15 years agoJTAG programming with blank EPCS16
I have two PCBs, a master and slave, each with a Cyclone III FPGA on it. The JTAG pins of the slave board are connected to IO pins on the master board. The first board has an Ethernet connecti...
15 years agoperhaps the following document may help you
http://www.altera.com/literature/an/an425.pdf table 2 use the do_halt_on_chip_cc command
