9 years agoJTAG Programming successfull but no effect at the ouput
I am using a Cyclone III EP3C120F484 device for my custom board. When I connect the USB Blaster and run the JTAG programmer in Quartus, the programming is done with no error. The code is just writt...
9 years agoCONF_DONE should be HIGH after programming. This is true when programming using any method. When in JTAG mode the programmer monitors the status of CONF_DONE through the JTAG port.
Before and during programming, user I/O will be tri-stated and pulled up via internal pull-up resistors. So, if "Everything is tied to 3.3V" - and CONF_DONE is LOW, then your device is not programmed and you are looking at the internal pull-ups that are active on each I/O pin. Some other things to check: 1) Is nCE tied to GND? 2) Are both CONF_DONE & nSTATUS pulled up externally? Have you looked through the "configuration, design security, and remote system upgrades in the cyclone iii device family (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/cyc3/cyc3_ciii51016.pdf)" section of the handbook? Cheers, Alex
