12 years agoJTAG programming successful but no output on hardware
I am using a Cyclone III EP3C10F256 device. When I connect the USB Blaster and run the JTAG programmer in Quartus, the programming is done with no error. The code is just written to tie a few outputs...
12 years agoDave, I fixed the problem of different VCCIO's I mentioned in my previous post. The pin planning is perfect (pin assignments and VCCIO voltages) but the problem of not getting any outputs is not fixed. Do you have any ideas?
