14 years agoJTAG interface
Hello, I would like to interface Cyclone IV JTAG interface via both ways : 1. JTAG USB blaster. 2. FTDI FT2232 MPSSE interface. I am using VCCIO 3.3V in Jtag bank and in figure 8-23 in c...
14 years ago --- Quote Start --- For the resistor I may use a 22ohm resistor, as I have one already in my design, but what would be the effect on the TCK line, if the resistance is not right, because I dont want to have to rework the PCB once it is made. I will only be using the one FPGA device in my design. --- Quote End --- 22-Ohms will be fine. The key thing is that you have a resistor footprint on the PCB. That way if you do see ringing on the TCK line, you can adjust its value without a re-spin of the PCB. Cheers, Dave
