Rmc_Arira's avatar
Rmc_Arira
6 years ago
JTAG error using USB Blaster with MAX10
Using MAX 10 device, 10M04SCU169C8G
Attempting to program using Quartus Prime Progammer Pro Edition 2020
with USB Blaster (rev C) Note: this is USB Blaster, not the USB Blaster II
The Programmer can auto-detect the part, and properly identifies it. But when I go to execute any function (program, verify, blank check or erase) I get
Error(209040): Can't access JTAG chain
I have tried running the JTAG Chain Debugger (found under the tools tab). It passes the test
!Info: JTAG chain connection is good. Detected 1 device(s)
!Info: Device 1: 10M04S(A|C) (USERCODE: 0x0009CEC1)
I have looked at the JTAG signals on an oscilloscope, they look good.
I have looked for an error log that would tell me more than just "error" but I can't find such a log.
What is wrong?
Rod
  • matthewd's avatar
    matthewd
    Hi Rod,
    I'm having the same issue. What ended up being your solution?
    Thank you,
    Matt
  • Hi,
    This case is the same as case 04731479 , hence i will continue to assist you in case 04731479 and close this case.
    Aiman
