8 years agoJTAG contacts problem
Good afternoon, members of the forum. I have a used card with a Stratix V chip. For a long time I could not get connected by jtag. I decided to use a multimeter to measure the contacts from t...
8 years agoPresuming you have checked correct function of your USB Blaster by using it with a different board, I see two possible reasons for JTAG failure
- FPGA is held in POR due to missing or to too low supply voltage for one of the monitored nodes - FPGA JTAG interface has been damaged JTAG pull-up and pull-down resistor can be varied in certain range without affecting correct operation.
