8 years agoJTAG contacts problem
Good afternoon, members of the forum. I have a used card with a Stratix V chip. For a long time I could not get connected by jtag. I decided to use a multimeter to measure the contacts from t...
8 years ago --- Quote Start --- Hi, How BSDL will help in this case, can you help me in understanding? You need to go with hardware changes only. or If you are ready to do some experiments than, You can try to modify pin assignments in USB Blaster in firmware, If you get that program for you max device. Not Recommended --- Quote End --- Thank you so much. It turns out I did not correctly check. Now I checked all the contacts and the circuit was assembled correctly. But now the values of the resistors in the diagram show not the naminal - red and blue values. Resistors are definitely worth the new ones, even if you remove the resistors, the circuit still shows such values. Do you think the chip itself?
