8 years agoJTAG contacts problem
Good afternoon, members of the forum. I have a used card with a Stratix V chip. For a long time I could not get connected by jtag. I decided to use a multimeter to measure the contacts from t...
8 years ago --- Quote Start --- Hi, Not possible through firmware because it is having dedicated pins & function.It can be only done through hardware design. For correcting it you required hardware change. You can design a adapter with help of dot-matrix board and BergStik connectors with stack-up arrangements and use. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) --- Quote End --- Thanks. I decided to download the bsdl file from the alteras site, replace there two contacts in places and try running jtag scanning. In a few hours I'll try
