12 years agoJTAG Configuration - conf_done pin always low, even pull-up
After Board power-on, the conf_done pin which is also 10k pulled-up to 3.2V, but the pin is stick to low. the pull-up is not working for this pin. No short to GND. After power-on device, 16...
12 years ago --- Quote Start --- 1. JTAG configuration can be implemented without any settings. --- Quote End --- Hi, I also thought this as the handbook seems to indicate this, but in the past someone has posted here with a similar problem and finally the problem seemed to be a "invalid" i.e. not specified configuration of the MSEL pins. Seems like the better interpretation is "JTAG can be used for every MSEL configuration of the specified ones".. Just as a sidenote :-)
