12 years agoJTAG Configuration - conf_done pin always low, even pull-up
After Board power-on, the conf_done pin which is also 10k pulled-up to 3.2V, but the pin is stick to low. the pull-up is not working for this pin. No short to GND. After power-on device, 16...
12 years ago1. spec says msel should be gnd(0000) for JTAG Configurtion. it looks fine.
2. Doubt the BGA soldering on conf_done pin. because pull-up itself is not working. 3. Total 70 Devices are detected included the last EP3C25F device as shown. Checked the configurations on pull-up/down with device(3.3V IO) and USB Blaster (3.3V Power) and VCCA, VCCINT, VCCIO. all looks folow the spec. Determining the resodering the Device. Any suggestions ?
