12 years agoJTAG Configuration - conf_done pin always low, even pull-up
After Board power-on, the conf_done pin which is also 10k pulled-up to 3.2V, but the pin is stick to low. the pull-up is not working for this pin. No short to GND. After power-on device, 16...
12 years agoI'm just shooting in the dark, but are the M0,1,2 pins connected correctly? Does your device have an exposed pad on the bottom? Are you sure it's connected to gnd?
