17 years agoJrunner + Serial Flash Loader (SFL) + EPCS4 [How to programm EPCS without Quartus II]
Hello, I'd like to adapt Jrunner to work with Serial Flash Loader. I've integrated SFL megafunction into my design and it works great. When I click auto detect in quartus II programmer it detects ...
17 years agoHello
No many answers for you unfortunately! I'm interested by your topic, because I use the remote update megafunction, but it is only possible to read program to EPCS, and not possible to write into EPCS... so I try to find a solution. I have read that there is a solution with the NIOS, but I don't use it. I have an other microcontroller. I have found the Serial Flash Loader, this megafunction is a solution to have access to EPCS pins I think? But how should I design to write a program into EPCS? Do I have to use commands described in the EPCS datasheet? Did you find a solution? Or is there someone who know? (I use a stratix3 and EPCS64) See this link anyway, may help : epcs docs and datasheets (http://www.altera.com/support/devices/programming/configuration/prg-configuration.html?gsa_pos=8&wt.oss_r=1&wt.oss=serial%20configuration%20device%20epcs64)
