VBalamurugan29
2 months agoJESD204B RX Link Never Achieves CGS at 12.8 Gbps on S10 ES (1SG280LU3F50E3VGS1, Quartus Pro 17.1)
Hi Team, I am using the Intel JESD204B RX Example Design on a Stratix 10 GX Engineering Sample FPGA (1SG280LU3F50E3VGS1, L-Tile) with Quartus Prime Pro 17.1.I have two JESD204B configurations using ...
CheepinC_altera
2 months agoHi,
Regarding your inquiry on the known limitation of JESD204B IP max data rate in S10 ES, as I searched through the web data base, I come across this KDB which should be applicable to your use case. Based on this KDB, it seems like the max data rate supported by JESD204B IP for your specific ES part is 11Gbps. This could explain the link is not working at 12.8Gbps but working at 8.192Gbps. Thank you.
https://community.altera.com/kb/knowledge-base/is-there-a-known-problem-with-the-jesd204b-ip-maximum-data-rate-supported-by-int/344127
