Jesd204B IP force F = 2 when use phy only wrapper
Dear Intel Support/Expert,
While I use Platform Designer to generate an Jesd204b IP. I need LMF = 4,16, 8. but once I change the Wrapper options to "Phy Only", after I click save, the LMF will be forced to LMF = 4,16, 2.
is there any limitation when select "Phy Only"?
- skbeh
Contributor
An update, this is not a bug. In fact F parameter only use in transport layer (MAC layer). When you select Phy-Only mode with Physical Layer only, the F parameter can be ignore not use.
- skbeh
Contributor
This issue has been reported to the IP developer.
The plan is to fix this JESD204B Phy-only wrapper issue in next Quartus software release.
- skbeh
Contributor
Hi Sir
I have also tried these LMF settings on PHY-only mode, F value always being default to '2' after clicking the 'Generate HDL'.
My understanding is that this configuration is not supported, hence it's forced to change to 2.
